RE: Crazy wacky Electronics!
it can be either low batt or your ant wire may be broken in a spot and grounding out. i would pull the reciever and check all the wires starting wirh the ant wire, batt wire ,servo wires.if they seem all ok, then see if the ant wire may be touching metal. if this all checks out then maybe someone is messing on your channel.
