RE: TF Contender
Hey Fellows: Answer this for me? I have started my wing, also. I have all the appropriate pcs. glued to W-1 and W-2.
I have my spar pinned down and I am ready to set ribs. I notice that W-l has a small tab on the leading edge that none of the others have. This keeps the leading edge of the rib from coming in contact with the building board. The picture showing
that you must glue a little tab on the side of the rib on the trailing edge of the rib does not show this little tab on the leading edge. Of course, I have tabs on all of the trailing edges on all ribs. But only W-1 has these little tabs on leading edge. Do I remove them before I set the ribs or is this to leave space for sheeting later?
If necessary I can take picture of the rib.
Jim
AMA 821369
