RCU Forums - View Single Post - Sig Somethin' Extra Build
Old 02-06-2006 | 12:48 AM
  #146
somegeek's Avatar
somegeek
Default RE: Sig Somethin' Extra Build
Got the right wing sheeted, sanded and end cap installed(still need to clean up the end cap a touch).
Again, holding off on the W1 rib installation until the fuselage is done so I can sand where needed on rib W1A so W1 rib lays flat against the fuselage and W1A.
Fuselage glued and weighted in place. Did a bunch of checking from front to back before and after adding the glue and getting in place to verify the sides are square. Good to go!
