Hi Henner,
Futaba cannot recommend anything other than the 16K Campac that is manufactured for the 9CH. You certainly can buy extra 16K campacs and keep more models on them if you find that one is not doing the job for you.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Futaba Service Center USA
ORIGINAL: Henner
I have a 2001 9CHP with a Campac Module making total model storage capability of 14. Unfortunately my fleet exceeds 14 and I need more memory. I know it is possible to delete one aircraft, and reset for something else, but that becomes a real chore when you must always trim the new aircraft, and retrim again if you go back to flying one of the previously deleted models.
Are there any larger Campac modules made ? Will they fit in this 9CHP ? Is it possible to buy several Campac Modules and interchange them without losing model memory ?
Thanks in advance for you help ?
