RE: Official Smartech Thread
docphysics...
1) on the controller, make sure the throttle trim adjustment is in the middle position
2) idle screw: with car on and brake applied, opening of throttle plate should be no more than 1-1.5mm, just enought to keep the car running.
3) high needle: 3 turns from the fully closed position.
This will get you started.
