RCU Forums - View Single Post - Bdavison's E-flite Blade Assembly
Old 02-06-2006 | 02:29 PM
  #353
L0stS0ul's Avatar
L0stS0ul
Default RE: Bdavison's E-flite Blade Assembly
I've replaced both motors and I've checked the capacitors.
The GWS receiver is an ok receiver. the Quality control on them is just really bad. I've had 4 bad ones and 2 good ones. When they are good they are good though. This receiver has range tested fine and showed no glitching in my MHO. I think the problem is one of the speed controllers in the 4-in-1. Once I got the receiver away from the 4-in-1 the problem decreased greatly. It only ever starts to glitch when my hands go near the 4-in-1. I can hold it anywhere else and have no issues.
I did not want to spend $60 on an Electron 6 if this didn't work. I already had the crystal so the test only cost me $25
I think my revo is currently
LO -5
HI -20
My throttle and pitch curves are below:
Normal Pitch curve: 40,40,50,75,100
Normal Throttle curve: 0,25,50,75,100
Idle Up (1) Pitch curve: 0,25,50,75,100
Idle Up (1) Throttle curve: 100,75,50,75,100
Idle Up (2) Pitch curve: 0,25,50,75,100
Idle Up (2) Throttle curve: 100,100,100,100,100
Idle 2 is what Ron Osinski recommends. He says that
It will not blow up or overspeed. The KV of the motor and gear ratio will not let it damage anything. The t/r will hold better since the main motor is more constant and things will run cooler.
My Revo settings work better in idle up modes than they do in normal mode because the normal setup is not linear and the REVO settings are a linear curve. So I have the revo set to a switch that I turn on once I switch into idle up.
