RE: Insight build...another wood roach.
always check the prop.. i will learn from this.
If that's an APC prop, the hub is very hard---often a good idea to cyano a disc of 80-100 grade wet-and dry sandpaper to it and/or the spinner backplate---they can slip even if done up tight ,even directly against a knurled alloy prop driver. Same thing with a carbon prop.
