RCU Forums - View Single Post - Engine choice for small plane
Old 02-07-2006 | 09:07 AM
MikeG4936's Avatar
MikeG4936
Default RE: Engine choice for small plane
Thanks for the advice!
gcb - I'm not exactly sure what you mean whe you say "don't underestimate your Enya" - while I very well may end up using it, I think you are the only one I've heard of that said it was better than average.
Sport_Pilot - Concerning the plane - I was thinking about reinforcing it also (other people have mentioned this in other threads), but I don't think I should add any weight if I go with the Enya - I think it will have just enough power as it is...
Flypaper 2 - The OS engine I have is the MAX .25 R/C - it's older than both the LA and FP you mentioned.
gcb - What RPMs were you getting with your Enya .15 III? (Just curious).
Thanks for all the advide - can't tell you how much this helps with the decision!!
