RE: u-can-do 60
All,
I have been busy with the Do! Did the dowel insert to beef up the LG block, looks good and clean mounted the 100 and all the bells and whistles under the cowl (wow a chor) but I must say she is taking form! I glued the belly pan to the main wing and well I think I moved it too far forward! Yes its a real tight time trying to get the wing mounted so I am going to have to trim something somewhere to give!
I noticed that the Saito 100 carb sits about a 1/4" below the center of the fuel tank I might have to dremel it out (the round hole) and lower the tank if it is going to be a problem! I also moved up the easy fuel fueler to about the level of the carb so that it wont flood as I have read in some of the threads. I think I read somewhere that if I loop the fuel line from the fueler up higher than the carb then back to the carb inlet it could reduce flooding? Any truth to that guys???
Any advise on lowering the tank? Do I need to ? Ok all advise is greatly appreciated! I need the help! Gonna try and tackle the belly pan mod tonight! It just kills me that I must have messed it up! Thanks again!
Chuck
