RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 02-07-2006 | 11:18 AM
  #4135
raideron's Avatar
raideron
Default RE: U-Can-Do 3d 46?
Gary... I hear you about getting shot here in AZ land......, Even tho growth has
been unbelievable[:@] these last 3-5 years here... It's still not as bad as say in
some of the closer states... But rummaging through anything here will bring
the old west back....
I also think you'll be ok at your CG setting... I know I was having problems with
my "Do" when I went to the S100 in holding the inverted flat spin, it went into it
fine, but it wanted to loop back out at the slightest throttle increase. I moved my
CG back, put some mixes in, used low rates/expo. etc... Then I just went back
to the normal settings and just worked the sticks... I never quite worked it out,
But I did have a couple great spins/rising spins by just waiting a bit longer and
letting the "Do" set into the stall before adding too much throttle before she died.
But as you know, having "Monsters on the nose" Makes for delayed subtle
changes..IMO..... Guess more reason to just start off with the Monster
