RCU Forums - View Single Post - exponential
Thread: exponential
Old 02-07-2006 | 12:45 PM
bruce88123
Default RE: exponential
netdudeuk - One thing you can do is go inside your transmitter and adjust your stick spring pressure. I believe the procedure will be in your manual and is very easy. I have mine as high as they will go. Futaba also sells stiffer springs I've heard but I don't need that much. Stick length is also adjustable if desired.
