RCU Forums - View Single Post - Tower Hobbies .46 engine
Old 02-07-2006 | 02:25 PM
mikeboyd
Default RE: Tower Hobbies .46 engine
Mike, Totally agree with everything you put in the post about this engine. Just to add my $.02. I found the same trends when I used the Tower muffler on the OS and Magnum .46's and .50's. That muffler is amazing, It will add a little over ,1200 RPM's on 15% Nitro on other engines, over their stock mufflers. But the increase in performance also requires some refined tweaking to get the engine dialed in. The engine picks up allot more RPM's in the air, than on the ground, since the muffler sort of acts like a tune pipe, it will cause the engine to demand more fuel in the air than on the ground, therefor go lean and die, burn out the plug and maybe the engine.
Just for the sake of arguement, I put an OS .46 FX muffler on a Tower engine and found it easier to tune, but nearly lethargic in performance. I too, found that the engine likes an idle bar and a fairly rich setting on the high end and very lean on the bottom, similar to a large SuperTigre engine.
I have had several of these just for fun, to fool around with. I had one come apart before the first gallon, sent it to Hobby Services and got another new engine right back. It worked great, using your recipe. Like SuperTigres and Magnums, these engines need to be broken in and tweaked quite a bit for the first two gallons, but after that, they run like the proverbial scalded ape.
Remember you usually get what you pay for, but if it comes with a long warranty, make use of the warranty. I have had similar problems with Magnum .52's, but with a Tower muffler, good break-in and some patient tuning, they are awesome on power. If you are a Tower member, they usually double the warranty on all tower products, making some of their stuff a very good deal for heavy, prolonged usage.
Good luck and happy landings.
ORIGINAL: XTOL
We were slowly leaning it out through out the flights..
Here is where you went wrong. You got it too lean. Forget what you
know about setting engines on the ground. This thing leans out a LOT
in the air. If you set it like you do for most other engines (a little rich from peak)
it will lean out and die in the air.
It has to be WAY rich on the ground. Its kind of hard to judge
but through trial and error and lots of deadstick practice you
can get it dialed in. Once you hit the magic combination it
actually runs really well.
Also it seems to be picky about plugs. The one we had did not
respond well to Tower plugs or os#8s. We had the best results
with a Fox idle bar plug. I dont really like Fox plugs but in this
case it worked a lot better.
Mike Hammer
