RE: Air Hogs Aero Ace!
Hi Nick et al:
I'm out in LA on a trip and bought an AA at the local Tar-Jay (Target for those of you who are not of the French persuasion) and it was a C channel. It's a little laggy on the throttle but otherwise works just fine, like the others.
I split the fuse carefully on the seam with an Xacto per Nick's instructions, pried the thing open enough to see what was going on in there, then sliced out a bit of the foam forward of the battery, moved it forward (probably an inch or so), squeezed it all together with some CA, took it out and it flies like a dream. Very stable, only does the porpoise pitch when it gets hit with a little gust. Thanks Nick!
I have a little dinner plate foam I'm going to make some wing extensions per my earlier posted adventures and turn this puppy into another miniature soaring machine. Love these little airplanes.
