...but I think that's more due to the swirling slip stream hitting the rudder and fuse, than to what's described as the P-Factor. And the reason this is so much worse on a tail dragger than a tri gear, is that a trigear has the steering wheel firmly planted on the tarmac until lift off, whereas the tail dragger has the tail flagging in the air, very succeptical to any air stream.
This, sir, is just plain wrong.
