RE: Hitec Flash5 Problem
First, make sure the exponential is disabled. Be aware that, if you open the case, you void all warranties. That being said, you can open the case and check for loose components that can be easily tightened. Unless you have electronic experience, and a Technician's repair license, the next step is to send it back to Hitec.
Dr.1
