RCU Forums - View Single Post - setting idle and fuel mixture
Old 02-08-2006 | 12:46 PM
gschofield
Default RE: setting idle and fuel mixture
Ok, I think I got it, when I pull the car off the ground the wheels spin, but when I put it back on the ground it just sort of creeps very slowly, which is good. My next problem, and this is one I"ve had since I got the truck, is that when starting for the first time of the day the engine stalls when I remove the glow plug ignitor. Is this normal? The idle also seems to slow a bit when I remove it. I have a brand new glow plug ignitor and it's fully charged. I also just changed the glow plug. Other than that I think I might finally have this thing running well. Do you have any idea where the engine should be mounted. Like how close to the transmission? Again these are probably dumb questions but I am new to this but I enjoy the work on them. Thanks for your help.
