ORIGINAL: Cisco-Kid
It actually moves PAST idle when I apply just a little bit of pressure in the down direction. Then it snaps back to idle when I release it. It should just stop dead at the bottme, but does'nt. I hope I'm being clear.
Reminds me of 'Spinal Tap' ....'This one goes to eleven'.
I wish my radio had that problem. It sounds like a very good kill switch that doesn't require a button. Anyone know a good patent attorney? You shouldn't be banging the throttle down real hard unless you are killing the engine anyway.
If there is a problem with the stick, adjustment should be fairly simple, it is on JR and Airtronics anyway.
