I recently purchased 4 NEW
527's (JR) as part of a flight pack. I had intended to use them on a Hobbico Spectrum I am now putting together (what a nightmare). I had already installed 517's in the wing and wanted to test the throws. After hooking up the switch and battery I tested the 517's and everything worked perfectly, smooth as silk. Wanting to use the 527's on other functions, I hooked them up to the receiver and all went absolutely nuts. am overlooking something or did I get hosed on the purchase? I tried changing switch harness..same thing. I even hooked the battery direct to the receiver and you guessed it, same thing. I even tried using batteries in different states of charge, Nicads and Nimh made no difference. Help!
