RCU Forums - View Single Post - What gas engine to use
Old 02-08-2006 | 08:20 PM
RTK's Avatar
RTK
Default RE: What gas engine to use
Disco---A stock lightened Ralph Cunningham 62 with ignition is at 4lbs a stock 58 with out ignition is at 4 lbs. Where are you getting your numbers from? Or am I wrong?
ORIGINAL: DiscoWings
The mvvs58 with a factory canister weighs the same as the zenoah converted so its not any heavier either.
