RCU Forums - View Single Post - Radio box solution??
Old 02-08-2006 | 10:03 PM
SManMTB's Avatar
SManMTB
Default RE: Radio box solution??
JJJEEEFFFFFF is right. It might affect the range some unless you have 100% of the wire outside the box.
Been there done that.... had an antenna mounted directly onto CF once in a RC boat. The range dropped to around 30ft. Needless to say the boat took off and ended up on the other side of the lake with the engine running WOT @ 125730rpm.
Be careful.
