ORIGINAL: sxates
Hey guys--after hearing so much about the AA, I picked one up this morning. I think its really cool, but mine seems to have an issue of always turning left. It's like the right motor is just faster, as nothing I do seems able to correct it. It's much more than the trim and rudder can handle. Without touching the right stick, it just flies in circles, and trying to turn right will get it going straight, and just a little to the right. Makes it pretty difficult to manuever as you can imagine. Has anyone had this problem and been able to fix it? Kinda makes me want to take it back and exchange it, and try my chances again. Appreciate any help--and overlooking the fact that I haven't had time to read all 20 pages to see if its already been discussed
you didn't mention whether you tried adjusting the little dial on the TX to correct the turn. That little nob can help a lot...but don't put it all the way to the right, as it will, for some reason, suddenly make the turn to the left worse! Just adjust all the way to the right, then back up a smidge. If it's still not going straight by then, take it back...but
all my AAs turned left at first, and I was able to get them all adjusted just fine.
