RCU Forums - View Single Post - Air Hogs Aero Ace!
Old 02-09-2006 | 02:04 PM
  #489
skypix
Default RE: Air Hogs Aero Ace!
ORIGINAL: sxates
Well, I was about to say "yeah, I tried that" but I gave it another shot and you're right. All the way to the right doesn't help at all, but back off a bit and suddenly it works. Thanks for the tip!
you bet...did it take care of the turn? tweaking the elevators a bit might help without costing too much performance...carefully slit along the lines scored on the elevators...put the silver tabs on there if you haven't (one on the rudder too). bend the left elev slightly down, right one slightly up. see if that helps...it'll put power off turn into it too, but maybe that will be an improvement.
