RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 02-09-2006 | 03:33 PM
  #2136
toprudder
Default RE: E-FLIGHT BLADE CP
ORIGINAL: jeffdom1978
Wow, thanks for that reply Toprudder.
Yea, I did get the CP2 Version 2. I am still awaiting its arrival. I also purchased the training kit and an extra Lipo 1300mah battery.
Should i order a heat sink too? I'm thinking about placing an order for extra blades and a heat sink.
Anything else i should get?
thanks!!!
I don't know if you really need the heatsink or not. I had bought the aero upgrade for the BCP, so I had them anyway. I'm sure the heatsinks would not hurt. BTW, my son has a Blade CX, and the motors get hot on that, so I think I will get a heatsink for those.
Extra parts?? Rotor blades and main shaft are the big ones, maybe the landing skids also. The really nice thing about the HB is that the shaft can be removed out of the top since the gear is not molded onto the shaft. I just had to do that to mine, I bent that shaft slightly and was able to pull it out of the top, straighten it, and put it back in just a few minutes.
