RCU Forums - View Single Post - stripped screw HELP!!!
Old 02-09-2006 | 07:53 PM
quango2k
Default RE: stripped screw HELP!!!
buy a dremel kit..probably the best bit of kit you will ever buy! they are reasonable cheap too..
i would cut a slit in the top of the screw with a dremel, hold the engine tight if it turns with the screw, maybe spray a little wd40 in there to loosen things up.
