wing mounted servo ?
First thanks to all who answer my questions... im sure my plane will be a much better build because of all of you and the forum.
Im mounting a servo in the wing of my Eagle 2 trainer wing. It is a wooden servo frame. The question is .... Since servos use a rubber gromet ( I suspect to reduce vibrations to the servo ) should the fit of the servo into the servo tray be loose or tight. Should the fit be loose as to lower vibration to the servo?
Thanks again....
