RE: Installing CA Hinges
I cut a slot with a exacto knife, just a slice, install the hinge, put a t-pin on the front edge down through the middle; slide on the control surface, add 2 drops of ca to top and 1 drop to the bottom using thin ca. you will never pull them out, I have tried.
