RCU Forums - View Single Post - stripped screw HELP!!!
Old 02-09-2006 | 10:29 PM
RCDAD2
Default RE: stripped screw HELP!!!
Alittle more indepth here
Warm the piece that the screw is in NOT the screw up to 200-250 like nascardad said than use compressed air shooting threw a THIN tube at the screw it self
Why heat expands items cold contracts ....i do this to fix stuff thats rusted or stripped all the time
JUST be carefull NOT TO OVERHEAT the car or the mounts you can ruin them
Another way get some penetrating oil puts some dabs onto it leave it overnight to soak in try again in the morning (so you dont overheat yourself)
Dremel also works in some cases as well it just depends on the situation
is the bolt loose & stripped or tight & stripped ???
can you remount the other screws to the engine and try and back the stuck one out
just a few idea's good luck getting it out
