RE: Propeller Sizes
SuperAirborne,
Increasing speed and vertical performance are almost totally opposite things. If you increase your speed you lose vertical performance, and vice versa. There are always trade offs when selecting props. What you need to do is decided which is the most important to you and then select a prop accordingly. As was said before, higher pitch props give you more speed and lower pitch props give you more pulling power for vertical performance.
Ken
