RCU Forums - View Single Post - My new Matrix ARR
Old 02-10-2006 | 10:55 AM
badSN95
Default RE: My new Matrix ARR
MXS12 + MXS14 are the caster blocks. They are the same part but have different angles for steering adjustment.
I would stock A arms, different size pinions, a set of diff gears, stock or pro spur gear( I haven't had a problem with the spur since I got the PRO) and a wing and maybe mounts too(mine are still on there but barely)
I really haven't broke anything that wasn't my fault.
I broke center diff gears twice but I think they weren't shimmed right. I broke each of my steering knuckles(one had a loose bolt which caused the failure, the other broke from impact with the front stretch wall)
The servo saver broke because it was too tight from factory(I replaced it with a custom made aluminum one).
If I think of more I will repost.
I can't wait for warm weather here. I have been to the outdoor track and it was sweet. The local indoor track isn't big enough for the speed of 1/8 buggies. Supposed to get big snow on Sat.-Sun. I have to get some paddle tires to play in it.
