bobcat construction Q
Silver solder requires a torch(flame) and the proper flux to work properly.
The higher the silver content, the higher the temp required and
the stronger the joint will be.
If the material is clean, the proper flux is used and enough heat is applied, silver solder is a joy to work with.
Johnny
