RE: U-Can-Do 3d 46?
Has anyone had trouble with the Cowl? I'm tring to assemble mine and it seems as though the engine mount is located too low on the firewall which forces the cowl to point slightly downward, or the cowl has the wrong angle on the face. I end end up with a much larger gap at the bottom than the top when I'm trying to possition it for mounting. It almost seems as thought the engine should be higher on the firewall to match the cowl, but it appears to be possitioned correctly for the aircraft.
Note: I'm using supplied mount and a Saito 82.
Thanks, Chris
