RE: Stupid Glow Starter Question
You pull on the tab to pull back the cover on the tip of the starter and push it onto the top of hte plug. It should clamp on..then start it up and once its started I like to leave it on for about 5 seconds to make sure its warmed up enough to keep an idle then you can remove it.
