RCU Forums - View Single Post - Lanier Yak
Thread: Lanier Yak
Old 02-10-2006 | 07:47 PM
  #213
3DFlight
Default RE: Lanier Yak
Maudib,
Great job, what's the secret for such clean looking lightning holes? Also, you were right about Lanier and single ailerons. Talked to them today and they said they had never flown one with one servo per wing. Really advised against because of the size of the ailerons.
I really like the looks of a pilot, so, I called Gerhard at Aircraft International and ordered one of his very light foam pilots. I have one in my 33% Ultimate and 37% Katana and they weigh about an ounce. With your skills you may be able to hollow the figure a little and cut that in half.
Curious, on the tail tubes from Graphtech, did they have .490" size? I have Graphtech main gear, tail gear and wing tube in my 37% Kat. Left the aluminum tubes in the tail for weight as I had already mounted the rudder servo in the cockpit area.
What engine are you planning on using?
Blue Skies & Fair Winds,
Rege Hall
