ORIGINAL: andyt
I you bothered to search you would find that there is at least 2 other owners of Evolutions that are claiming 6300 and 6800 on 24/10s one right underneath your post.
Break it in with a petroleum based oil and not the one that came with it... Use Penzoil Air Cool 2-stroke.
The engines are totally bullet proof once broken in, can swing a 26x10 @ 6000 rpm,
Best prop for 3-d on them is a 23x10 bolly, spooling to 7400 rpm VERY quickly.
For imac type flying a 24x10 would be really good
Again thats your quote.
Perhaps if you had followed the instructions and not "broken it" in with Pennzoil which they dont want you to do you would have better luck.
Seems your the only one so far that I can find and I bet they sold more than 3.
Maybe swap it out for a DA which you trashed so well.
That is the information that I recieved directly from Tom Facet; The 23x10 prop was determined to be the best for 3-d after reading a post on downonthedeck.com (I would post a link to it but dod just changed to a new message board...) That prop was on the MVVS58 which happened to be on a WH edge.
Ohh as for your penzoil claim, Here I posted about that as well:
http://www.rcuniverse.com/forum/m_37...tm.htm#3764397 Notice I specifically asked weather or not to USE, the INCLUDED OIL. Based on the test we did on site, people found little to no difference between synthetic or petroleum oil when mixed in the same ratio in terms of performance.
DA, please rather not fly then even try a DA
Why do you keep posting? I got your numbers and yoursetup. Wasn't it made clear for posters just to post their numbers of the 58 Evolution engine? If you insist they are the same engines, how about you swap them out for 2 Evo58s which are making 5600 rpm
After all they are the same engine right? I have 3 people that would be happy to give their engine to you.
