RCU Forums - View Single Post - buggy: full body???
Old 12-07-2002 | 03:57 PM
Dempy
Default Re: Full body
Originally posted by RURC
OK here we go.
What you have their is either a Ofna or a Sinyah. Both of them are so close in appearance that unless I can get much better photos I can't tell the differance. I have both and they are great racers. In any event your best bet to do this is one that will require a little time on your part. I suggest that you get 3 photos of your car one whole car (no body) from the top, one close up of the front end from the top (spicifially the diff housing needs to be seen) and do the same to the rear with the rear wing removed to get the best view. The photos need to be high quality so that when you sent them to the address below they can blow them up and look at some spicific mounting aeras for the new body mounts. Secondally you will need to look at their selection of bodies at the site listed below. This is not hard but it will take some time. If you want me to see if I can do this for you then I still need the photos so I can determine whtch mount set you need. Once this is done uou will mount your body with no problems.
Site to look at bodies : http://www.robs*********.com/lexan_bodies
Site and address to look at and send photos for mount kit : [email protected]
http://www.dahms-intl.com/
My email address [email protected]
Mike
THNX
