RCU Forums - View Single Post - Engine choice for small plane
Old 02-11-2006 | 11:56 AM
NM2K
My Feedback: (14)
Default RE: Engine choice for small plane
ORIGINAL: Sport_Pilot
I have the same ARF kit, and I am planning to put a modern Fox .15 on it. It is also iron piston steel sleeve, but it will turn an 8-4 prop at almost 15,000 revs. Not sure it it will hover with that old Enya. What nitro fuel did you use? Some of those older .15's needed high nitro fuel, such as Cox racing or Missle Mist.
Thinking of reinforcing the plastic fuse on this model. Not sure how, but thinking of gluing some 3/16" square balsa, in four courners and top, to the rear former and gluing the stabilizer to that. Or maybe it will hold up fine without?
The Fox .15 ball bearing is a good engine, but it nearly weighs as much as a plain bearing .25.
Nitro doesn't hurt the small engines one iota, that's for sure. However, I don't think I would go with 40% nitro in it. IIRC, that's what the Cox Racing Fuel is.
When it came time to buy a bunch of .15's, I opted for two Thunder Tiger and two Enya plain bearing .15's, because of their light weight. With light engines, you don't need to worry as much about beefing up much of anything.
