I use it....... removing stripped and broken fasteners is an art form
Every job calls for a different method, the one suggested was fine for a countersunk screw going through the chassis. You want something fun, try removing a bolt an easyout broke off in, or a broken tap, both are miserable. The other guy said try heating screw, that was not bad advice either, thread lock compound releases at temperature. At least you got it out.
