RCU Forums - View Single Post - Typhoon Problem - No, not servos...
Old 02-11-2006 | 02:43 PM
jdetray's Avatar
jdetray
Default RE: Typhoon Problem - No, not servos...
You don't mention what type of motor you are using. If it's a brushless, it could be that a magnet was knocked loose during your crash. Or a wire in the motor may have been broken.
Incidentally, it is the motor that actually makes the beeping noises. The ESC uses the motor as a "speaker" of sorts to generate its sounds.
- Jeff
