RCU Forums - View Single Post - Help request on ARF repair
Old 02-12-2006 | 01:57 PM
cptkirk
Default Help request on ARF repair
I bought a tail damaged ARF Trainer a couple of days ago. Pictures are posted of the damaged area. Wondering if anyone can give me some adviice on how best to remove the Vertical Satbilizer. It's glued in with a wood block epoxied to the side of it. The balsa has some cracking and I would like to build a new satb. Unsure of the best way to remove the old so I can use it as a pattern to build a new vertical.
Thanks for any wisdom you can share.
ID:	406815   Click image for larger version
ID:	406816   Click image for larger version
ID:	406817   Click image for larger version
ID:	406818   Click image for larger version
ID:	406819   Click image for larger version
