RCU Forums - View Single Post - broke in my mvvs 49
Old 02-12-2006 | 02:16 PM
DarZeelon's Avatar
DarZeelon
Default RE: broke in my mvvs 49
Asmund,
I did write this before.
The 15,000 claim is not even for the Jett .76L BSE engine....
It requires 2.04 HP to spin a 12.25x3.75W this fast.
Lies are not true claims...
This is not within the capability of any engine I can think of right now.
My break-in thread deals with 'when can you start using the engine normally', to signal the end of the break-in process.
MVVS engines do gain a lot of additional power; around 600 RPM within the 6-10 hours after the break-in.
Your engine seems to be too low on power, for it to be a case of needing more break-in time.
Something is out of adjustment and most likely it is the tuned exhaust.
Do try to find a way to measure RPM, in daylight, without using the torch/flashlight.
It can also be a case of an inaccurate sampling.
Did you try to tach another engine at the same time and got a more positive result?
