RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 02-12-2006 | 03:02 PM
  #4173
raideron's Avatar
raideron
Default RE: U-Can-Do 3d 46?
CrashBurn69... I know people that use CA for the tail feathers, and has had no
problems... But IMO... For hi stress areas I use 30min epoxy.. I just feel safer
It all cleans good with pre-readied paper towels and alcohol... The main thing
here is DO NOT score the bulsa when removing the covering....
sl1200mk2.... The 91 should do good, The 82 would have had about the same
power with less weight.... IMO I would not go to the 72... Up is better:-)
Your servos seems good, maybe over kill on the rudder... I was using standard
Hitec BB servos(57oz) on all but the rudder 83oz on 6v.. It did all that I wanted
to do...
I do not do too good on fuel time.. Lot's of deadsticks.... But when I was running
the S-100 on mine I was getting over 12mins with the 10oz tank.... But most my
flying was with low throttle use.
The nose of the "D0" is a bit small.. The 10oz just fit's without mods... Guess you
could find taller tanks that would fit.. But it would have to be fitted in... If I
remember correctly some of the earlier "Do's" came with 8oz tanks???? At least
my "used" "Do" had an 8oz.. And the member I got it from said that's want came
with the plane.... After installing the S-100 I put the 10oz tank in....
