RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 02-12-2006 | 04:23 PM
  #2171
TeufelHundin
Default RE: E-FLIGHT BLADE CP
If you are going to switch to JR radio, gyro, esc depending on the gyro it can be easy or a little tougher. If your gyro draws a low enough amount of power you can use a JR receiver with a 2-in-1 controller and fly away. If you are using something like a Futaba 401 the 2-in-1 cannot power it as well as the flight electronics. That leaves you with two options use a separate receiver battery or use a combination of the 2-in-1 and another esc like the pixi 20. The setup would be as follows:
You need a Y harness to connect the throttle connection side of both the 2-in-1 and the main esc this will plug into the throttle channel on the receiver. You then need to connect the battery inputs for both esc either by Y harness or just solder them.
You then connect the pixi esc to the main motor and you connect the tail motor to the 2-in-1 leaving the main motor output on the 2-in-1 open.
The gyro connects to the rudder channel on the receiver and to the rudder input on the 2-in-1.
This setup will also allow a brushless main motor by substituting a brushless esc in place of the pixi esc.
