ORIGINAL: andyt
Any comments to confirm or dismiss (with proof) would make it very informative to people considering picking this engine up
You asked if they were the same engine and a lot of other questions (bearings/ignition).
I have attempted to answer.
You asked in the link if you should run synthetic.
You were told you should.
Mvvs say you should run MX2T and give you some to start and then High quality Racing synthetic.
Evolution say the same.
You choose to run SEMI synthetic and take a loose test to support yourself.
You still havent said what prop your running.
You still wonder where you have lost 1000 rpm
Or are you talking about some other engine now.
See ya
6400 and climbing
I asked people to post their readings, you posted but still seem to hang around repeating yourself over and over. Like reading your own posts?
Your readings do not increase the readings other people are getting. How do you propose to give other people 1000 or so increase in readings?
So far, you are the exception and not the rule; ever think of the possibility they had a bad production run on the engine?
Wanting to See other peoples tach readings FOR THE EVOLUTION 58, NOT MVVS58.
If you dont' have this engine, don't bother posting because it means jack
