Originally posted by coony2787
By the way kinda off the subject but did that dave patrick extra fly that good out of the box (so ta speak)
Chad
Yes the DP Extra is stock! DP builds them really good and light. The newer version suppose to be 1.5lbs lighter.
Originally posted by FilipM
We need to find a nylon engine mount that will take 160-180 motors, who sells something like that?
The only nylon mount I can find that might fit the Moki is by FUNKEY or Yellow Aircraft. There is also an alluminum by JTEC for Moki's and that weights 3.9oz, the original Moki round back plate is 4.6oz. These are a lot better than H9's 7oz. mount.
Originally posted by Welsh3D
Mine is 12lbs with a gasser and still rubbish for 3D.... the model itself is hardly any good for 3D.... tried all different CG's.. settles on the hingleline at tip.
Welsh3D, how did you get yours to 12Lbs? and with a gasser? Which Gas engine?? I know the moki 1.8 is like 4.3lbs.
The plane is an OK 3Der, just gotta get it ligher. Harriers and elevators are pretty cool with spoileron mixing. My biggest problem is the power to weight ratio, my plane is 13.5lbs and the moki only produces an 18.3lbs thrust.
