RCU Forums - View Single Post - Throttle Curve
Old 02-13-2006 | 01:13 AM
mikenlapaz
Default RE: Throttle Curve
Sounds reasonable but have only used a 9C. Additionally I'm curious as to how you set your endpoints and linkage. Do you have them set to maximize the full throw range of the servo (140 on each side of center); What are the distances on the servo and carb respectively of the linkage attachment points to the center of rotation? How many degrees of angle do you have on the carb from idle to the butterfly being fully open?
