RE: Aerobird Extreme motor upgrade available?
Do a search for reverse timing a brushed motor and you'll find all kinds of good info on it. The motor is timed neutral at the factory to work as a tractor or pusher setup. Since the Extreme is a pusher you can reverse time it for a bit more speed and power. It's simple and only involves rotating the back plate to a static marking.
