RE: FP heloCP blades on FP helo
Has anyone done a brushless tail motor? I read before that a brushless motor might not be sensitive enough to speed changes to work well in the tail. They have a hard time running at low RPM. That's why you need soft-start programmed into your ESC on the main motor. Otherwise it'll kick the heli around violently when you start it up.
