RE: BME 50 Lack of spark?
You just need a new sensor...When the ground strap breaks the spark goes to the closest ground, in this case it's the sensor...You should get a spark when you flip the ignition on and off...If not, the ignition is bad..Not very likely....A different ignition won't make any difference....[8D]
