Use 3x of those round lithium batteries (#2032) in series. Each one is 3v and will give you 9v. This will eliminate the extra weight of the 9v battery.
ORIGINAL: djdavidcp
ORIGINAL: catfight
Doug,
I tried the same thing but my video was not as clear as yours. What camera are you using and did you use a separate 9v. batt or heli battery?
Catfight,
I got the camera for $75 from here:
http://www.raidentech.com/24ghzmiwicoc.html
I used a 9V battery, but I have the camera right under the 4 in 1.... I'm going to move things around a bit, make a mount, and get a higher gain antenna for the receiver, then it should work better. I just went oustide and shot a quick video, and I'm not all that pleased with the results. But I should be able to make it work with some tweeking.....
Here is the outdoor test... Mostly a view of my Observatory
http://www.dougsuniverse.net/images/BCP_Outdoor.wmv
Doug
