RCU Forums - View Single Post - DA50 mid range burbling
Old 02-13-2006 | 04:20 PM
Stuart G
Default RE: DA50 mid range burbling
Thanks for your replies guy's, I guess I will just have to be patient and run more fuel through it then adjust low needle a bit more. As far as the length of header goes I have not altered the standard length and connot make it any longer as the can will not go any further back as it will hit the wing spar, but i will be able to shorten it if needle adjustments are not the cure.
